hi i im getting 3 warning lights coming on ,it was ok untill i got it bk from the garage after getting it lowered,they dont come on straight away its about 5mins after drivin,the ones that r on r the brake light whitch is normal,it gose of when u use the brakes,the other 2 r the number plate light warning and the one below that one,i have checked the bulbs and they r all workin fine,has any one else had this prob,how was it resolved...........
thanks for lookin
warning lights above rear view mirror coming on
?? Number plate warning LED IS on the bottom row!kris66 wrote:,the other 2 r the number plate light warning and the one below that one,i
kris66
i am reading frm top to bottem on the left hand side,sorry for getting the order wrong!!!
You've lost me! They're all labeled. Which ones are coming on?
kris66
the one`s that r coming or r.... number plate ,brake light ,and the other brake light one,they all run in a row frm top to bottem on the left as u look up at it,as i have said i have checked all the bulbs and they r fine...
thanks
thanks
The three LEDs down the left side are brake lights, number plate lights and tail lights. All three of these are triggered by the bulb failure module on the left side of the boot.
Other thing that is common between them is that they all use the same earthing point which should be somewhere around the left rear of the rear seat base. Check the ciondition of this connection.
kris66
thanks for that,i will give that a go..
chris
chris
