The Touring has mismatched headlights - smiley on the left, normal on the right. Would like to get them both to smileys.
Is it possible just to replace the individual light, or do you need to do the cluster?
Thks,
Scott
Headlight question
Easy to swap just the light unit.
Remove complete headlamp assembly and twist the three adjusters through 90 degrees where they fit into the black plastic frame.
Copper grease the headlamp adjusters.
SD
Thanks Brian
