Hey Zone. How do you remove the rear bumper on a 4 door 316i?
cheers
rear bumper
look under the bumper and you will see 2 bolts. Remove bolts first then bumper
smithy318i
there are 2 T55 torx bolts on the bottom of the bumper.
Just undo them and it slides off.
randomdave325
- Random E30 Nutta
if they are mega tight i find it easier to take of the 4 13mm nuts off the dampers and slide them out with it. i think3 are underneath and 1 in the boot. look at the end of the chassis legs. after have one of the nuts snap and spin on the long torx bolt. i learnt from it. that was a bugger to get out!
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise'
Fraz06
thanx for your help guys much appreciated
