check panel
DJ_B4L
Post Sun May 14, 2006 2:05 pm
has any one ever fitted one of these to there car i have a 318i cab wanted to know of one of these can be fitted or not
and is there wiring there or would it needed to be fitted
i have seen them in the 320i's and the 325i's
they are the check panels that show you all the lights coolant and eveything is ok
Post Sun May 14, 2006 2:18 pm
You could fit one but for the work involved its not worth it. Cars with check control have different looms
Post Sun May 14, 2006 3:50 pm
You could hook up the coolant and oil levels without too much work, but the lamp failure functions would really need a complete loom and fusebox change.
oze30
Post Sun May 14, 2006 4:01 pm
im interested in this mod as I have just converted from manual to electric roof with thge sunroof pod.. so it's either get a check control panel.. and just make it sit there doing nothing.. OR.. making it work as much as possible.. OR.. A little mystery winkeye
DJ_B4L
Post Sun May 14, 2006 5:18 pm
yeh i thought it prob need a different loom as i have fitted a 325i Obc in my car its working fine just thought the other check panel prob was easy to install
oz how much did you pay to get your roof to electric?
Post Sun May 14, 2006 9:19 pm
Would imagine what ever the local scrappy charges. They usually cost me about £5, when I buy with a load of other stuff.
If you get the stuff from a scrappy, take the motor panel and the outer guide tubes complete, leaving the spiral inner cables behind. (unscrew the motor to allow them to slide out), and take the loom all the way down to the accesories socket behind the glovebox.
oze30
Post Mon May 15, 2006 9:04 am
£50
but that included headlining/front/rear windows/motor/console
Need to go back and grab the rest.. only just worked out how to swap the main parts over to elec.. and my guide thingy's are busted
DJ_B4L
Post Mon May 15, 2006 10:59 am
thats cheap they got any more beemers? or leathers for a cab?
oze30
Post Mon May 15, 2006 1:43 pm
sorry.. no more.
