My cars starting to become a joke.So far today ive lost count of how many times it stalls.It runs fine once warmed up,but for at least 5 minutes it stalls at most junctions unless the car is kept moving,its actually starting to get dangerous as i dont realise instantly (music on etc) and its hard to keep the car moving constantly.I may get my dad to have a look (Mechanic) but hes ill at the moment,so if theres anything i can try that would be good.
Ive got a Viper2 chip to install, which may bump the Idle level up a tiny bit, but any other options?
Idle problems.......stalling all the time.
SwirlyE30
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
Ant
- Retired Team Member
Easy check items:
Pull the rubber boot off the TB and cheack for splits in it, bend it around a bit and see whats what.
spray carb cleaner around the intake side of the head with the engine running and see if the idle speeds up a tad, if so spray in small areas til you locate the source.
clean out the Idle control valve with same carb cleaner, can be Very crudded up and cause grief as desribed.
Whatever you do dont chip the car until this problem is sorted, oh and whats wrong with a Zone chip anyways??
HTH for starters..
HTH for starters..
bottlecapE30
my guess is that it is the idle control valve if you take it off and spray carb cleaner in it,and clean it out it should stop it for a while till you can get a new one. if that does nothing then it is most likely the idle modual. hope this helps
SwirlyE30
Cheers boys.Where abouts is the idle control valve located? I might go home and try somthing later, i think theirs some carb cleaning in the garage.
Ant-Nothing wrong with them mate!
Just got me hands one one of these instead
Also mate (trying not to sound like a complete newbie) where abouts on the 4 pots is the intake.Havnt looked at my engine yet, not to clued upspray carb cleaner around the intake side of the head with the engine running and see if the idle speeds up a tad, if so spray in small areas til you locate the source.
Ant
Intake ? ,its the bunch of bananas cast in alloy hanging off the passenger side of the head:lol:
ICV looks like a small motor but will have two hoses going in and out of it , one of which is plumbed into the intake rubber bellows.
M10/M40/M42 engine ??
SwirlyE30
Cheers matey.
Its a 1.8i so M40.
Ill try and have a look later on, and let you boys know whats happening.Bloody cars.....This weather dont help,my cars fucking freezing till i drive it hard,thats porbably not helping it
Its a 1.8i so M40.
