play in steering
e30-320i
when driving on the motorway it feels as though my steering is a bit loose and i'm constantly making minor steering movements to keep the car in a straight line i know alot of it is tramlining due to my wheels and the fact i live next to felixstowe docks so thousands of truck up and down the roads but i'm wondering how much play there should be in this part not sure what its called hence (crap) pic.if i hold it and move it side to side there's about 5mm play each way does something need replacing
89 325i touring
stuartgallafant
hi there fella, the part you are looking at there is called the steering coupling...
there should be no play in this part at all, so 5mm is bad!! this is due to the coupling 'donut' (not the sugary variety!) being worn or split, allowing movement/freeplay.
the donut is the black rubber disc, btween the two ends of the shaft
to rectify this, the bottom of the coupling must be removed from the steering rack, and then the four 13mm nuts can be undone. then you can change the donut, and put everything back together
hope this helps mate
e30-320i
cheers mate that sounds pretty staightforward and hopefully not expensive as it's just a bit of rubber
89 325i touring
stuartgallafant
e30-320i
cheers dude will do
89 325i touring
