320i into 325i...how hard?????
eltel
Post Wed May 10, 2006 3:44 pm
i would like to swap my 1988 320 6cyl engine for a similar aged 325 engine...how much work would it take and would diff, prop, gearbox electrics have to be changed.
or is it a straight swap?????
Hyperion
Post Wed May 10, 2006 4:57 pm
straight swap mate, everything should be fine.
g57yle
Boost Junkie
Post Wed May 10, 2006 7:59 pm
it couldnt be more simple. even the wiring loom is the same.
Its a basic in and out job
the 320i gearbox even fits
but if you want to fit the 325 gearbox then you will normally need to change the prop shaft aswel as it is normally shorter on the 325i as the gearbox is slightly longer.
another thing i reccomend is to put a large case 325i diff in aswel as youll find the normall 320i small case diff breaks very easilly. i went through 3 in a week!
Good luck
fowler
Boost Junkie
Post Wed May 10, 2006 8:02 pm
hello mate i have a complete 325 set up as i did this conversion pm for info
EX A-Tech Workshop bitch !!!
gone but not forgotten
