Electric windows not working. HELP ME S.O.S.
dn808e2
Post Tue May 09, 2006 6:40 pm
Hi help me stupid :mad: .
I took it off and now it's not working
i sending a vodeo file to show you guys how stupid i am
Thanks :D
http://s60.yousendit.com/d.aspx?
id=3EJ3L2N05I8D303JCS9I6YI69V
i look stupid god dam'
e30-320i
Post Tue May 09, 2006 6:51 pm
can,t see vid
89 325i touring
dn808e2
Post Tue May 09, 2006 7:02 pm
Try this link ,
once it open , the file is ready to donwnload
http://s60.yousendit.com/d.aspx?id=3EJ3 ... CS9I6YI69V
realy need help
thanks lads
toby
Post Tue May 09, 2006 7:22 pm
First simple question - have you tried pressing the button next to the electric window switch (the circuit breaker switch) to see if you get it working?
dn808e2
Post Tue May 09, 2006 7:31 pm
yes man i pressed it
no lillumination of the switches
it should be when i take the key from the lock
smithy318i
Post Tue May 09, 2006 8:13 pm
very good idea with the video by the way.
do you own a meter for reading voltage? if you do, conect it to the fat brown wire amd the fat green wire. and make sure you have 12 volts. (if you don't own a meter, you can use a lightbulb)
the big black plug with 2 green wires on it isn't used for anything. the power should be from under the dashboard, not form the cigarette lighter. trace the fat green wire back to the blue relay, you should be getting power from there.
dn808e2
Post Tue May 09, 2006 8:56 pm
thanks Smith :D last night i ask a guy to run through the wireing loom
starting from them brown and white slots that go to the switches
then he tasted the power on fuse box number 17 fuse , it was ok
i'll try to f..k about little bit more than if i woun't be able to get it right
coul someone who's got bit of experience to help me out .
I'm in King's Lynn so if it's not too far from me i could pop in
Thanks anyway
P.S it's just bit hot in the car during the day but the rest is fine :D
toby
Post Tue May 09, 2006 9:31 pm
I really hope you manage to sort this quick mate.
Can I ask - what were you doing in the interior when it all went wrong? It may help to know what other compnents you may have moved while down there.
Hopefully
dn808e2
Post Tue May 09, 2006 10:30 pm
i decided to see whether it possible to remove gear liver without taking gear box out (was thinking to put short shift ) and now
all the ppl like ppl and only me drivinn' with windows shut when outside + 25C
dn808e2
Post Wed May 10, 2006 3:56 pm
It's working now :D :D
