fuse
iil325i
im having probs with my sport, a fuse keeps going, its the 1 that dose the heaters and all the gages all i have is a speedo, has any1 had this befor,
i'm gonna blow my fuse if u keep selling things, then not selling, then selling to other people. Propper pissed off now, the strut brace was one thing the wheels are the icing on the cake
iil325i
sorry m8 some 1 has said they want them befor you did, what am i ment to do m8
cliffybabe
- Powered by Nelly
iil325i
R ur reverse lights working??? or are they on all the time or anything wierd??
iil325i
i will look, but no one has said anything
cliffybabe
- Powered by Nelly
only reason i ask is when my fuse kept blowing i had ripped the revse light cable (the reverse switch cable) off the gear box as it got caught up in the drive shaft doughnut.
Once i had sorted the cable it stopped th efusem blowing
iil325i
ok i will look, its well f**ked up it done it friday night then 3 times sunday now its ok again ????
cliffybabe
- Powered by Nelly
sounds about right, The only reason i found out it was the cable was due to my mate syaing my light reverse lights were always on
iil325i
lol i think my m8 had the same sort of thing now you say that it might be when i use the hand brake, as i dont use much i leave it in gear
