eta 2.7 firing order
Aziz
Post Mon May 08, 2006 4:40 pm
Hi guys
Its been a couple of weeks working on this engine ready to go into my 1987 325i sport I've had the engine out.
325 (885) Head off fitted a 284/272 shrick cam reasembled the head.
But....I'm not sure of the cylinder firing order to position the cam a pistons in the correct order.
can anyone help????
Cheers Imran :?
Templ8e30
Post Mon May 08, 2006 5:04 pm
All M20 six cylinder engines have the same firing sequence which is 1-5-3-6-2-4
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Aziz
Post Mon May 08, 2006 5:07 pm
8)
Ant
Retired Team Member
Retired Team Member
Post Mon May 08, 2006 8:00 pm
dude, please be aware that if you had your block decked you must not use the standard cam drive wheel, a vernier is a muct have item M8
