Been looking at different suspension options for a while now and was almost settled on Bilstein Sports shocks and 40/30 springs for my 318iS - that little lot will come to about £550. But now i'm considering the H&R Cup kit along with the H&R arbs from the zone shop - £600 in total. From what i've read so far, both the spring/damper kits and the arbs sound fantastic, but i have a few questions....
First, the iS is already 20mm lower than normal right? so 40/30 springs would actually only be 20/10 (not much difference) and the 60/40 kit will be 40/20mm lower which is a bit more like it
Also, i've read that M3 suspension bushes at the front are a good idea - what's peoples opinions on this?
And are there any other parts i should get before starting the job? Any changes i need to make anywhere to keep the geometry right? Anything at all that i should know before doing this as i'm a bit inept when it comes to cars though pretty good at mechanical things once i get stuck in (i just take ages to finish the job!)
Thanks in advance for any advice
Simon
