M40 mixture adjustment?
KelvinBrown
Post Fri May 05, 2006 1:21 pm
Hi guys.
How do i adjust the mixture?
The MOT station said it was very weak
M40 engine.
KelvinBrown
Post Sun May 07, 2006 11:47 pm
Cough ! :(
Post Sun May 07, 2006 11:57 pm
Mixture is controlled by the map in the ECU and is non adjustable.
I expect your MOT man is referring to the idle CO adjustment.
This is adjusted by a screw near the engine end of the airflow meter, which may have a red plastic plug covering it.
It works by adjusting the amount of air that bypasses the flap in the air flow meter, thus fooling the ECU as to the amount of air entering the engine at idle.
It can only be adjusted properly by attaching a gas analyser to the exhaust pipe.
