Blue Temperature Sensor
MATHOMAS32
Post Thu May 04, 2006 12:39 pm
Hi All
Am i right in thinking that if i disconnect the blue temp sensor while the engine is running and the revs rise this means that the sensor is working ok?
Globulator
Post Thu May 04, 2006 2:19 pm
Just measure it (engine off) when cold, the resistance should be around 2000 ohms - falling as the engine warms.
If in doubt they are less than £20 from a dealer and take about 1 minute to change with a 19mm s/plug socket.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Post Thu May 04, 2006 6:54 pm
Disconnecting blue temp sensor would make the ECU think the engine is extremely cold, so it would increase the revs and badly overfuel.
Proves that it works, in that it does something, but doesn't prove that it's within spec.
