revs dont hold at idle
nasir325ic
Post Thu May 04, 2006 12:15 pm
just got my cab out, but the revs dont hold whislt on idle, keeps on turning off, is there anything i can adjust ?????
thanks
wildeian
Post Thu May 04, 2006 1:24 pm
Do you mean you just got it out of storage?
If the ECU has been without power for a while, it will need time to check/adjust settings.
nasir325ic
Post Thu May 04, 2006 1:38 pm
yea came out of storage, it needs a tune, but local garage cant do it till next week, so tempararily i kno theres something you can adjust but dont know what
any way your suggestion....... how long wil that take?
nasir325ic
Post Fri May 05, 2006 7:46 am
some one must know what to do?
Post Fri May 05, 2006 9:29 am
nasir325ic wrote:some one must know what to do?
There're aren't any adjustments as such. The ECU takes care of it all, and has to relearn settings.
Drive the thing, and if it doesn't improve, look for splits in the big rubber hose between the airfilter and the throttle body, clean out the idle control valve with carb cleaner, and check out the throttle position switch by ear and with a meter.
nasir325ic
Post Fri May 05, 2006 10:32 am
yea i just checked that rubber thing and it did have a split in it,
I covered it and the cars fine now, wats that rubber thing called anyway?
jez
Post Fri May 05, 2006 1:06 pm
realoem call it a rubber boot? anyway they are around £18 from the dealer
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Fri May 05, 2006 1:21 pm
i paid £12 from the BMW dealer in grange over sands and they sent it to me 1st class post free of charge.
