I've cleaned it out as best I can, re-assembled everything and just carried out an electrical check on it.
Pins 1 & 2 are short cct with the throttle closed but go open cct with the TPS 'click' & the throttle just off idle point.
All OK there so I'm led to believe.
Pins 1 & 3 are open cct, but no matter what the position of the throttle, they don't go short cct.
I thought this was supposed to happen at about the 2/3 throttle point?
Could this be the source of the intermittent, erratic RPM problem this car has been having, for me and previous owners???
