steering rack removal?
alan325i
How easy is it to change a steering rack on a 325i, i have a power steering rack and would it be better to have a non pwer steering rack in it as i heard you can feel the road better with one.
Widge
No too difficult, jack it up remove the mounting bolts and ball joints and losen the steering column joint, it should then pull out forwards, although some "modification" of the lower tabs downwards is a lot of help. The remove the pump and reservoir. Bingo replace with manual rack.
cliffybabe
- Powered by Nelly
be careful when pulling it off I knocked myself out last weekend changing my rack
Widge
Wot like falt out counting stars on the drive???????
That would have been a sight for sore eyes!
WerkdE30
i have driven power and non power steering e30's i really dont suggest it.
if your car is pre facelift then i think changing to a post facelift model rack will make the steering heavier giving a better feel.
not 100% sure on that tho but they certainly feel different.
cliffybabe
- Powered by Nelly
Yeah like i was laying under the car with my ad kicking me saying stop mucking around job and i was out of it for about 5 - 10 mins.Widge wrote:Wot like falt out counting stars on the drive???????![]()
It was bloody funny, after i come round i started to fit the new rack
Widge
cliffybabe wrote: It was bloody funny, after i come round i started to fit the new rack
gooner1
- Out humping Reindeer
Why would you need to change the racks,can you not just remove pump ,belt and block the pipes?
Widge
Yep you can, but I think you need to fill ethe old power rack with fluid or it'll start sieze up, it's not that difficult to remove one, think I may have to find a Sunbeam rack or whatever it was that makes the steering quicker, and is manual, nearly didn't get the lock off quick enough going round a round about the other day
was a little too close for my flatmate in the passenger seat.
