HELP!!!! I NEED TO RESET MY OBC IMMOBALIZER!!!!!!
e30bmlover
- Ac Schnitzer prophet
IM IN THE SHIT EVERYONE! MY MISSUS TOOK THE 320 UP TO THE SHOP, CAME BACK, PUT THE CODE INTO THE OBC AND NOW SHE CANT REMEMBER IT! I CANT START MY BLOODY CAR! DISCONNECTED THE BATTERY AND NO JOY!!! HELP ME BRIAN MOOOOOORE!
See "disabling a rogue engine immobilizer" thread.
e30bmlover
will it be the same wires even though the immobalizer was the original obc one?
Widge
I disconnected my battery when this happened., and it forgot the code.
Maybe you need to leave it for longer with the battery off. If you can get in it's one of the green wires above the glovebox which comes from the OBC and stops the fuel pump working.
Yes. If the car has an OE alarm as well, the alarm immob and OBC immob will be connected in series near the plug in question.e30bmlover wrote:will it be the same wires even though the immobalizer was the original obc one?
The immob interupts the ignition feed to the C101 connector.
Laughably easy to bypass.
P.S. If you want a secure alarm, arrange it to short circuit the fuel punp supply as well as break the ignition supply.
e30bmlover
done it! i owe you one brian!
