its recently been chipped but cant see if that would do this ive not had anything weird happen like this on any e30 ive had anyone ??
thanks ian.
Sounds like a good plan of action to me mate. I'm not sure what the going rate is for a pressure check, but if it needs a skim-(which i doubt) that will be under 50 notes. To be honest once you have it sorted it will be much nicer knowing that the headgasket won't blow, the cambelt won't snap etc etc. Should see it well into and beyond the 200k barrior.H35-IAN wrote:plan of action jon m8 was get it pressure tested , then get the valves reseated and sorted , skim head new water pump , cam belt & tensioner , new head bolts , head gasket hopefully all will be good i will do u a better picture of the gasket tomz anyway keep the thread updated shouldnt be too much to get that done surely?lol
