Fuel cap locked shut, HELP!
julianm40
Post Mon May 01, 2006 12:10 pm
The central locking packed up yesterday and I have no fuel and the cap is locked shut.
Ive tried looking for the white box mentioned in other threads but cant find it. Is there a way of unlocking the fuel cap without using the central locking?
eko
Old timer
Post Mon May 01, 2006 12:12 pm
Can you get in the boot?
If so,pull the panel out on the drivers side,you will see the selonoid there,slide the rod back manually.
Should open now!
dazleeds
old skool raver
old skool raver
Post Mon May 01, 2006 12:14 pm
remove grey side trim on drivers side in boot
then you will see the solonoid that locks petrol cap
slide the bar back if you can
if not remove the solonid carefully and ur petrol flap is open
hope that helps mate
Daz
www.oldskoolfantasy.co.uk
julianm40
Post Mon May 01, 2006 12:17 pm
Ok I'l try that now, cheers guys.
eko
Old timer
Post Mon May 01, 2006 12:19 pm
Julian,regarding the C/L fault,check the relay/fuse first,then do a search for Red/Black wire in tech section,very common fault with C/L failure!
julianm40
Post Mon May 01, 2006 1:36 pm
I did try that, but I cant find the white box. Is it under the black trim next to the sill?
Post Mon May 01, 2006 3:24 pm
There is no white box. Don't know where you got that from.
Central locking ECU is black, and lives directly under the drivers footwell loudspeaker, BUT is probably not at fault anyway.
Do a forum search using my username and red/black, and you will find how to cure 75% of CL problems.
Regarding the fuel lid locking. There's no need to remove any trim. Theres a small flap in the trim that you push a hooked wire through
julianm40
Post Tue May 02, 2006 5:49 pm
Central locking randomly started working again.
Post Tue May 02, 2006 6:28 pm
julianm40 wrote:Central locking randomly started working again.
RED/BLACK WIRE!
