Brake calliper bleed nipple
One of my brake callipers bleed nipple's is getting hard to turn with a spanner. There isn't much left for the spanner to grip on to, but the calliper is otherwise good. Can the bleed nipple be replaced? Is it just a case of unscrewing it and putting in another?
smithy318i
absollutly ANY local discount auto parts shop will sell them. Cheap as chips. (make sure you ask for small ones though)
Lordschleife
- Contact:
This happened to both my front ones - had to file em down so a 6mm spanner would fit to remove them (and one of them still snapped off it was so rusted tight, lucky it loosened it as it snapped)
Bought new ones from BMW bit they're bit bloody pricey (£3-4 each!?)
So if you can get em elsewhere then do so
Cheers,
Robin
Robin
Any where will do them GSF or Euro or any local parts place like that Andrew Page or SAS if you have one. Make sure you take an old one in, and they'll be metric, as theres loads of different sizes. You'll probably get 10 for the price of 1 from BMW.
Halfords, ECP, GSF, GMD Motor Factors (Chester-le-street), Andrew Page, Partco. NOT ONE OF THEM SELLS THEM!
I tried them all earlier this month for a friends 316i. Stealer only and you often need to quote the VIN!
Shocking but true!
Shocking but true!
I simply can't believe that, but I guess if you've checked it must be so!johnna wrote:Halfords, ECP, GSF, GMD Motor Factors (Chester-le-street), Andrew Page, Partco. NOT ONE OF THEM SELLS THEM!
Shocking but true!
My mate's nipples were rotten and snapped under pressure. Sufficient metal was left to bang on an under sized socket 6mm/ 7/32af.
I told him to buy new, but he's still running on the old ones...
The reason they are not stocked is that they no longer fail. They do not rot like they used to.
I'd be interested to see if they can be bought over the counter away from BMW.
NB Motorforce don't stock them either...
Lordschleife
- Contact:
Well if you have to buy them from the stealr then 34.11.1.153.197 is the number for the front bleed screw on my 318iS, presume it'll be the same for all models?
Cheers,
Robin
Robin
smithy318i
AutoSport sell them for 80p (concord front street in washy)johnna wrote:Halfords, ECP, GSF, GMD Motor Factors (Chester-le-street), Andrew Page, Partco. NOT ONE OF THEM SELLS THEM!
Shocking but true!
Lordschleife
- Contact:
34.11.1.153.197 for the rears too according to realoem
Cheers,
Robin
Robin
Lordschleife
- Contact:
Cheers,
Robin
Robin
Lordschleife
- Contact:
WTF happened there?! triple post
Cheers,
Robin
Robin
Gwynleym10
- Contact:
Your a very brave man working in Columbia....!johnna wrote:I'm off to Autosport on Friday!
Working in Columbia now mate, next to the Snooker hall.
