Blue temp Resistance @ RT
smithy318i
Post Fri Apr 21, 2006 1:26 pm
Anyone know the correct value of the blue temp sensor at room temp?
Mine says 2.75K
Post Fri Apr 21, 2006 9:58 pm
smithy318i wrote:Anyone know the correct value of the blue temp sensor at room temp?
Mine says 2.75K
That's a little lower than the figure I use (3.9k), but it depends how hot your room is!
Stick it under the cold kitchen tap. That should be very close to a constant 5 degree C, and gave a reading of 3.4k on the good one I tested years ago.
Globulator
Post Sat Apr 22, 2006 8:51 pm
The new one I fitted today read 1.9k in the nice weather today.
I thought it was quite good actually as its <£17 from the dealer and
using a 19mm long 3/8 driver was a 1.5minute job :D
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
