ok -front lights a bit tempremental 'dipped beam warning on computer comes on, but a bit of fissling with wire behind the bulb housing does the trick.
Rear tho - on my passengers side when light is on 'normal' it is only half the brightness of the drivers side. (almost like side lights)
So, conclusion: the rear light works but only maybe 50% brightness??
what you think??
back light problem
stonesie
Check the bulb mate, I think mine are 10w but somone might have put a 5w in yours or it could be about to blow... they go dark, somtimes a silver colour before they finally blow
As opposed to what?innes wrote: Rear tho - on my passengers side when light is on 'normal' ??
Two possibilities come to mind:
1/ It may be exactly half brightness - if someone has fitted a 5W lamp instead of a 10W.
2/ E30 rear sidelight bulbs have a habit of the glass going blank, making the light dimmer and dimmer as time goes on.
innes
cheers guys, tried new bulb and have tried swapping the drivers side rear tailgate bulb with the passenger side.
STILL THE PASSENGER SIDE MAIN TAILGATE WONT BLOODY WORK!!
all the others work on that side (indicators, fogs reverse etc).,...
.... however, just noticed side repeater,(also on the passengers side) ISNT WORKING!
whats wrong with it, help!!
