Mystery Diff Noise
KDS
Post Sat Apr 15, 2006 6:21 pm
Over the past few months I've been hearing a strange sound coming from the back end (I assume the diff). Sort of a ghostly "woooooo" sound. It's engine speed related and disappears when the clutch is in. Any thoughts on what it is and what should be done about it?
-KDS in Vancouver ('88 325i Touring)
Strawb
Post Sat Apr 15, 2006 7:14 pm
KDS wrote:Over the past few months I've been hearing a strange sound coming from the back end (I assume the diff). Sort of a ghostly "woooooo" sound. It's engine speed related and disappears when the clutch is in. Any thoughts on what it is and what should be done about it?
iv been haveing this type of trouble on my car i thought it was the diff but the sound doesent go away once the cluch is in. it only happends when turning right so im thinking its the wheel bearing, does the noise change when you turn corners as well
Chris-W
Post Sat Apr 15, 2006 7:56 pm
If it stops with the clutch pedal pressed I'd say it was the thrust bearing.
KDS
Post Sat Apr 15, 2006 10:19 pm
Strawb wrote:does the noise change when you turn corners as well
Nope, I notice the noise consistently--corner or no corner. I definitely stops when the car is coasting in neutral.
Chris, is the thrust bearing what we North Americans might call the throw-out bearing?
Post Sun Apr 16, 2006 12:25 am
KDS wrote: Chris, is the thrust bearing what we North Americans might call the throw-out bearing?
Same thing.
Post Sun Apr 16, 2006 12:27 am
E30 diffs commonly develop a whine with age, but go on for many tens of thousands of miles with no ill effects.
