Fuse keeps blowing!!!
e30bemer
Nutters
Nutters
Post Thu Apr 13, 2006 9:50 pm
Hello People
Having a problem with my fuses!!!
Fuse 10 keeps blowing, have found out that it controls headlamps, heater blower and the dials!
Has anyone had this problem before?????
:wink:
Post Thu Apr 13, 2006 9:58 pm
e30bemer wrote: Has anyone had this problem before?????
:wink:
Loads of us!
You missed out reverse lights from your list. Pull up the gear lever gaiter and find a white two pin plug by the right hand side of the base of the gear lever. Pull this connector apart, and see if your fuse blowing stops.
If so, check out the wiring under the car from the gear lever grommet back to the reverse light switch on the gearbox.
e30bemer
Nutters
Nutters
Post Thu Apr 13, 2006 10:03 pm
must admit brian, i have just got back in, and wondered why my reversing lights wasnt working!!!
Will check in the morning!!
Cheers Mate :wink:
