Torsional Vibration Damper ?
bigpimpin
Post Thu Apr 13, 2006 8:23 pm
WTF?
Just started fitting my Propshaft to the gearbox (with a nice new Guibo winkeye ) and noticed this bloddy thing wasn't there! (NUMBER 3)
http://www.realoem.com/bmw/showparts.do ... g=26&fg=10
A question, Is it needed at all? It doesnt seem to have a part no on realoem and if you look at the one underneath it doesnt have one.
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :-x
www.m3touring.com
jmc330i
Post Thu Apr 13, 2006 8:40 pm
Is that the E30 M3 prop?
Im pretty sure mine didnt have one, in fact heres a pic (M3 prop on the bottom)....
Im almost sure it didnt have one when I fitted my prop (its a bit dark to go and check now).
James
'91 325i Sport
'93 318i touring 16v
bigpimpin
Post Thu Apr 13, 2006 9:13 pm
Hi James! Yeah its the M3 prop. I had to splash out on a new donut cause the spacing is different but didnt think too much about that "thing".
I think I'll just get similar bolts to the other 3 and that should do.
Cheers.
www.m3touring.com
Post Thu Apr 13, 2006 9:44 pm
The "thing" is a harmonic vibration damper, and can be left off with no noticeable ill effects.
IIRC, it had some minor effect with early guibos, but later ones are made of a better material, and the balancer is not needed.
bigpimpin
Post Fri Apr 14, 2006 9:18 am
Thats what I wanted to here!
:roll:
Full steam ahead !
www.m3touring.com
Post Fri Apr 14, 2006 9:57 am
There's another active thread somewhere on here about BMW front prop flanges and guibos. There appears to be two different diameters of BMW flanges (across different BMW models), and both 10mm and 12mm bolts are in use. The larger diameter seems always to use 12mm bolts, but the smaller ones can be either.
So, if you're using the smaller flange, check the bolt hole sizes.
