'89 325i sport nonstarter??
navi
hi 2 all, can anyone help i got an 89 325i sport bn runing fine headgausket went so left sitting about not used 2mounths approx in that time the battery when flat, took it off charged it up refitted it it wont start it spins over but dont apper 2b fireing fuel pumps fine anybody got anyidears?????? thanks.
wildeian
Mate, You should get the head gasket sorted before you try and start her up!
You could have dine serious damage if you have cranked it with a cylinder partly full of coolant.
navi
thanks 4 coment engine u/s anyway got a low mileage 1 2 go in need 2 start it so i can move it elsewere 2 change engine run it 4about 8 mounths with headgausket gone! it done well 2 get me about but it started smokeing really heavly so had 2 stop useing it sumps full of water iam woundering if the obc is not allowing it 2 fire up if not its gonner sit there 4 its fate 2 come try a few things 2day but no luck in the 3years ive owned it it all ways started never missed a beat any help would b a blessing!!!!!!!Brianmoooore wrote:You could have dine serious damage if you have cranked it with a cylinder partly full of coolant.
E30Mark
Is there a spark? fuel? what condition are the spark plugs in? if they have been left in a damp cylinder they will have corroded by now.
Any chance of some spell checking & punctuation in your questions, it will make reading it far easier, and more likely to prompt replies.
Best of luck !
Best of luck !
PM for details
PM for details
wildeian
If you try and start it up with water in the cylinder you will get a hydrostatic lock - pistons can't compress water so something else will have to give!!
Also, if water is in the sump the pickup will send it around the engine to lubricate, and water ain't a good lube!
I've seen the damage that can be done, and believe me you don't wanna be stood near it when the 'piston hits the fan!!'
My advise - tow it to where you need it to be!
navi
yer theres fuel preasant but no h.t at all change coil nowt could it b the obc theres a cut out built into that if iam right its never failed 2 start b4
navi
any more help b4 i burn it and claim! shame 2 c it go. theres no h.t at all is there any relays that control the ing circit if so were r thay??
Check, with a 12V lamp, not a meter, that there is 12V between the + terminal of the coil and the car bodywork or engine block, with the ignition on.
navi
thanks brain, iam getin wound up with this!!! i did put a direct feed on2 the pos side of coil and changed coil 2 nowt, i know engine is nackard thats y i got a low mileage 1 2 fit ,but as i cant get it started i dont wona pull it out till
i find y its not fireing it ran fine b4 battery went flat even in the state it was in. many thanks .wonted 2 get it fitted this w-end and start useing it.
Basic fault finding required then.
Take a plug out, reconnect its lead and lay it on the rocker cover. Crank the engine and check that it gives a good healthy spark once every two turns of the engine.
If it doesn't, then link out the main DME relay and try again.
Still no spark, then the crank position sensor is suspect.
navi
thanks, where is the dme relay to b found please?
Under the cover beside the coolant tank, along side the fuel pump relay.navi wrote:thanks, where is the dme relay to b found please?
When you said you have fuel present, do you mean under pressure in the fuel line?
navi
i belive so, am i rht in sayin the white relay is 4 fuel pump? if so this must have a live 2 it whitch would b the thick red 1? icant get 2 car now witch a pain, but it will give a chance 2 cool down thank you 4 being there!!Brianmoooore wrote:Under the cover beside the coolant tank, along side the fuel pump relay.navi wrote:thanks, where is the dme relay to b found please?
White relay is the DME (ECU) relay. Fuel pump relay is usually orange.
Spare socket is for a lambda sensor.
Link both relay sockets over, pin 30 to 87, but don't forget them and leave the links in place overnight.
navi
theres 2 blk relays and 1 wht no lambda fitted 2 car!did pull all 3 out pins all clean.Brianmoooore wrote:White relay is the DME (ECU) relay. Fuel pump relay is usually orange.
Very strange - should only be two in there.navi wrote:theres 2 blk relays and 1 wht no lambda fitted 2 car!did pull all 3 out pins all clean.Brianmoooore wrote:White relay is the DME (ECU) relay. Fuel pump relay is usually orange.
DME relay should have several red and red/white or red/yellow wires going to it.
Fuel relay should have red, red/white, brown/green and green/purple wires.
Lambda relay wires should all have green in them.
navi
thanks 4 your help going 2 bed now and sleep on it! will cheak coulor of wires when i can get 2 car again.big thank you 4 now b in touch- i know the car had kat the deleted from factorey if thts any help???the cars not b messed about with in the past iam only 3rd owner.Brianmoooore wrote:Very strange - should only be two in there.navi wrote:theres 2 blk relays and 1 wht no lambda fitted 2 car!did pull all 3 out pins all clean.Brianmoooore wrote:White relay is the DME (ECU) relay. Fuel pump relay is usually orange.
