what Steering Rack to use
bottlecapE30
Post Sun Apr 09, 2006 4:59 am
I have gotten fed up with my leaking skwaking steering rack :x and im going to go with one from Zionsville. what lock to lock turn should i go with? i want quick but i have heard that the 2.7 ratio will not stop the turn signal.
What do you guys think?
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
Post Sun Apr 09, 2006 10:55 am
Don't see the connection between changing the rack and the indicator cancel system, other than with increased steering rack movement relative to the column you're going to have to go around a tighter corner to actually engage the reset.
Post Sun Apr 09, 2006 11:13 am
Dont see it as much of a sacrifice really, I usually flick them off before the mechanism on the stalk gets chance
bottlecapE30
Post Sun Apr 09, 2006 4:06 pm
Thanks for the insight i will go with the 2.7 rack then
