320i injectors ??
samco
Post Wed Apr 05, 2006 9:19 pm
i've removed my inlet manifold to rewire the loom as it was cut etc while it's of i'm just wanting to know if there is an upgrade on the injectors or throttle bodie ??? any thing thing that can be done to the top end while i've got the injectors off and car off road.
money will pay amajor part !!!! winkeye
bottlecapE30
Post Thu Apr 06, 2006 4:41 am
you can use a 325i throttle body, and m50 injectors 18.75lbs or 5.0 mustang injectors 22lbs(?) either will work but the ecu needs some time to ease into the new injectors as the cycles will be off i would also go with an ajustable fuel pressuse regulator.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
Widge
Post Thu Apr 06, 2006 9:00 am
I think that stuff will be a bit of a waste of time you'll just end up over fuelling, unless you are building a 2.7 or are turboing there is no need for Mustang injectors. You could go for 2.5 injector and a 2.5 TB and inlet manifold, and port the head to mach - but then I think you'll probably end up over fulleing again. TBH mate, just get your injectors cleaned, fit a 2.5 TB and get a wild chip off ant.
chu346
Post Thu Apr 06, 2006 9:43 pm
Just put a different engine in winkeye
samco
Post Thu Apr 06, 2006 10:05 pm
i've just cleaned up the injectors but the question is now who's ant and how much for the chip???? :)
Widge
Post Thu Apr 06, 2006 10:09 pm
Zone shop mate, top of the screen. clicky linky.
