Fan Bearing
marinwolf
Post Wed Apr 05, 2006 1:38 pm
The bearing has gone on the fan.Can i remove and replace the bearing without having to take the rad out .i have 325i touring.cheers :?
mrLEE30
Post Wed Apr 05, 2006 2:38 pm
what fan, electric or viscous fan?
Widge
Post Wed Apr 05, 2006 2:40 pm
You can just replace the whole viscous fan, you'll need a 32mm spanner IIRC. If not then it's the bearing in the water pump. Which is a little bit more involved.
marinwolf
Post Wed Apr 05, 2006 3:51 pm
its the fan because the whole fan is loose and rubbing against the rad.its a viscous one .its only noisey at low speeds and start up.
Widge
Post Wed Apr 05, 2006 5:23 pm
Yeah I've got one if you want, you can get them from GFS too. You'll need a fan spanner really. And I'd get it done though mate, you'll be really pissed off when it dumps all the water :cry:
