2.5 M20 Head on Eta Block?
Project_E30
Post Wed Apr 05, 2006 1:33 pm
2.5 M20 Head on Eta Block, will this work??
Any details would be great!
da4x4turbo
Post Wed Apr 05, 2006 1:44 pm
when you say eta, do you mean 2.7 litre?
Anyone who knows of an S50 B32/B30 E30 for sale, please let me know.
Project_E30
Post Wed Apr 05, 2006 2:57 pm
da4x4turbo wrote:when you say eta, do you mean 2.7 litre?
Yes, just wondering if I can bolt a 2.5 head straight onto a eta block.
I have heard of a super eta 1988 onwards if this is any better?
I would be greatful for your help E30Zoners!!!!! :roll:
Quaser
Post Wed Apr 05, 2006 3:55 pm
Maasterbates has done this and he says it is running fine.
Project_E30
Post Wed Apr 05, 2006 4:06 pm
Quaser wrote:Maasterbates has done this and he says it is running fine.
Do you know exactly what he used/swaped?
And when you say running fine is that fine (OK) or fine (better than a standard 2.5)?
Quaser
Post Wed Apr 05, 2006 5:54 pm
afaik - standard 325i head, bolted to a 525e bottom end.
Needs chipping and the 325i anxillaries and job done - running more torquey they before - so better then standard!
Q
bottlecapE30
Post Thu Apr 06, 2006 4:51 am
be sure the block you use is post 88. if you use the pre 88 bottom end the compression ratio will be way to low. remmember that this rebuild is only good for about 100000miles not like a stock rebuild. just somthing to keep in mind :D
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
Project_E30
Post Thu Apr 06, 2006 10:37 am
bottlecapE30 wrote:be sure the block you use is post 88. if you use the pre 88 bottom end the compression ratio will be way to low. remmember that this rebuild is only good for about 100000miles not like a stock rebuild. just somthing to keep in mind :D
Are our eta's different to your US spec ones?
How can I tell if the block is a post 88 if its out of the car?
