Few niggly things with my car.....
Stickle
Wed Apr 05, 2006 12:09 am
1. Idles below 1000rpm.
2. Oil Temp gauge appears not to be working, max temp is apparently just 1/4. Oil levels are fine.
3. Water leak in boot, bottom left corner where the jack should be.
4. Pulls to the left, tried to have it tracked but my front right bush is going. What replacement would you recommend?
Any ideas and solutions to these would be appreciated, cheers.
ps. sorry, i know these have probably been asked loadsa times but my search through 5 pages of search results was fruitless.
Stickle
Wed Apr 05, 2006 12:10 am
By the way its a '90 318i.
smithy318i
Wed Apr 05, 2006 12:19 am
1. It is supposed to be 900 ish
2. Oil Temp ? are you sure? is it aftermarket addition?
3. check the light cluster seal first, by tightening the 8mm nuts.
4. cant recommend any as i have never replaced mine?
dazleeds
old skool raver
old skool raver
Wed Apr 05, 2006 12:26 am
boot seal or hole in inner arch is more likely
pull the side cover off and all will be revealed
eurocarparts or gfs
www.oldskoolfantasy.co.uk
