petrol smell from 325 cab
muzz
hi zoners from downunder just imported a 325 cab from uk driving it for about 2 weeks and have noticed a petrol smell strongest left hand side when the car has stopped not while the moter is running i will replace fuel filter today and lines to see if this helps any comments are welcome thanks muzz
Sooty
Hi Muzz.
Glad to see you got the message
LH side rear is most probably the flexible lines around the filter as you say(in front of the rear wheel) or, if it seems to be coming from the front, could be around the area of the fuel rail. I once had a leak from the rail return line to the tank, that only showed itself with the engine running.
I'm sure someone else will be along soon with other ideas.
Welcome to the zone BTW
Iain S
Iain S
PaulyV
Not an answer I am afraid but today I noticed exactly the same issue - left rear, and also in the engine bay a little both only when the system is under pressure evidently.
best
Pauly
best
Pauly
1990 318i LUX, Alpine White, 80,000 miles, as close to mint as I'll ever get.
Ziggy
Most common line I've found to go is the one from the filter to the rail... Easy enough to swap, so don't be tempted to just leave it!
Good choice of car & welcome to the zone
muzz
thanks for your replys and your warm welcome i think i will try the hit and miss method and try to replace the fuel lines and filters ect let you all know how i go chears muzz from oz
johnna
- E30Zone Irregular
$30~ for fuel hoses is not bad. Swap them all mate and then your barbie stays in the garden and does not start under the bonnet!
Globulator
I found the rubber pipe feeding the rail from the filter had perished on mine. It tucks under the manifold and gets quite warm - I suspect they always go first. It's a special bent BMW part, although I replaced mine with some regular marine fuel hose I had to hand and it works perfectly without being forced round any sharp corners.
On the rear left of the car I think is the fuel fump and I think fuel pulse damper (small chamber with 2 pipes) - I'd try the engine bay first though as petrol vapour tends to travel, and that is much easier to work on!
muzz
thanks all for advice it was the bent hosefrom the filter under the bonet to the fuel rail looked normal untill i put a fluro light in the engine bay the hose was spilt and cracked i replaced it with a peice of universal fuel injection fuel line bit more expensive than standard fuel line but is reinfoced and can flex without kinking allelulea no more nasty smells apriciate all the advice muzz from oz
