it is connected to the tightening of the bits that hold the seals, slack them off and it turns again, do them up finger tight and you then need a lever to turn the diff
Erm, i didn't have to undo any thing when i changed my seals(the dif wasn't fitted to the car though), just pull the splined hub thing out then lever the old seals out and push the new ones in ?
