Vibe during braking
nasir325ic
Mon Apr 03, 2006 2:53 pm
My car goes in to a crazy vibe when I hit the brakes, I feel it more at aound 35 mph or more, wat do you think's the problem?
Lordschleife
Mon Apr 03, 2006 2:54 pm
Dunno could be pad transfer? That can make the discs feel warped
Had you been using the brakes hard previously?
Cheers,
Robin
nasir325ic
Mon Apr 03, 2006 3:05 pm
not really? I just drive the car normal, dont usually slam or hit the brakes hard.
Wat do you mean by pad transfer?
Pads seem about half worn
TW166Y
Mon Apr 03, 2006 3:10 pm
sounds like shagged disks mate... have it looked at, wont take someone 2 mins to tell you :wink:
Saying goodbye to 4-pot wrongness
Chris-W
Mon Apr 03, 2006 3:54 pm
If it's discs you'll feel it though the pedal, if it's through the wheel only look elsewhere, eg. ball joints / track rod ends.
Lordschleife
Mon Apr 03, 2006 5:08 pm
nasir325ic wrote: Wat do you mean by pad transfer?
http://www.stoptech.com/tech_info/wp_wa ... disk.shtml
but I doubt its that if you've not been braking hard, or often leave you foot on the brakes for long distances
Cheers,
Robin
europameister
Mon Apr 03, 2006 5:48 pm
yeh get your discs checked out. Or just sell it to me.
nasir325ic
Mon Apr 03, 2006 6:28 pm
the vibes on the steering, not on the pedal, discs i think are fine thou.
Euro wat do u wanna buy? my knackered brake discs lol
europameister
Mon Apr 03, 2006 7:55 pm
il buy what ever your selling. You as well :D
samja
TW166Y
Mon Apr 03, 2006 9:26 pm
yeh as above...... if shaking when braking, you will feel it through pedal if not then i would suggest checking wishbone as mine was shaking at around 50mph and this was the problem
nasir325ic
Mon Apr 03, 2006 10:16 pm
TW166Y wrote:yeh as above...... if shaking when braking, you will feel it through pedal if not then i would suggest checking wishbone as mine was shaking at around 50mph and this was the problem
Was this wishbone problem expensive?
euro ive got a few teeth missing and that, but regularly serviced in UK workout in birstall. Not a council kid
Samja :cool:
Sooty
Mon Apr 03, 2006 10:58 pm
Something I learned from time in a race team.
If you use your brakes sufficient to get the discs hot, and then come to a halt & sit with your foot on the pedal (brakes applied), there is a build up of heat between the pads and the disc, while the rest of the disc radiates and disperses heat.
This causes the disc to warp. The severity of the warp is dependant on the amount of heat, duration of contact, etc but it IS evident.
Just think about it next time you stop at some traffic lights & can't be arsed to use the handbrake :wink:
TW166Y
Tue Apr 04, 2006 12:20 am
Samja :cool:
no mate £50 fitted :wink:
Lordschleife
Tue Apr 04, 2006 1:23 am
Sooty wrote:Something I learned from time in a race team.
Did you read the link above?
More likely to be pad transfer than actual warping, but the same effect at the end of the day!
Cheers,
Robin
Sooty
Tue Apr 04, 2006 6:37 pm
Yes Robin, I read the post :thumb:
Just thought it needed a bit of clarification is all :)
