throttle/acceleration 320i
zip88
Post Fri Feb 25, 2005 9:24 pm
my 320 has a flat spot just above idle,on idle in 2nd gear when decelerating it is a nightmare! when the car has backlash right
through to the diff! I have been told that the throttle switch is
at fault and possibly needs replacing? If it needs this can i go the exta
and fit a larger throttle body at the same time?and are these still
available through the zone .??
