The problem is I'm a total numpty when it comes to this sort of thing. Everything's got different names
Would anyone be kind enough to look up the part numbers I need on ECP or GSF?
The cars an '89 316i M40 2 door.
The bits my mechanic tells me I need are:
Trailing arms. Both sides. Not the bushes but the whole track control lower arm assembly. Both sides.
Front offside wheel bearing.
Nearside rear wheel cylinder (apparently the brake that side is a bit reluctant to work)
Thanks for your help. I really should learn more about cars.
Oooh, and I've just remembered. I also need the pipe that runs from the AFM to the manifold.
