Front wing removal
appletree
Thinking of removing front wing from an e30 in scrap yard, apart from the obvious bolts along the top under bonnet, where are the rest are there any sneeky welds. Do i need any special shaped spanners is it a pig of a job?
cheers
kam-325i
I think there is 2/3 at the bottom on the front of the sill and 1/2 behind the bumper/lights
fuzzy
im sure the one at the front under the light is a small torq head bolt.im sure the rest are 10mm bolts and posi head screws.is the car jacked up at the scrappys?they usually remove the wheels and sit them in the mud,which almost guarantees the ones at the bottom will be rusted.is the wing already painted the right colour as new ones from ECP are only £19.
scottybeemer
there is one or two that run down the door post side ,from the inside
"you aint gonna take me alive, copper"
appletree
to late
, went today only to find the car crushed under 4 others
