Angel Eye Headlights
parksie
Post Fri Mar 31, 2006 6:19 pm
Help!!!!
I'm not much kop with Electrics can anyone advise please.
Fitted the new lights OK, but got 2 cables don't know where they go cause no Instructions,!!!! ! 1 is a red wire with a roundtype connector via a fuse, the other is a black wire with a open u shaped connector.
I know several owners have done this ,and i'd be really chuffed if you can help,
Cheers Steve P
keggy
Post Fri Mar 31, 2006 6:59 pm
im guessin that the wires r for the 'halo' splice the red into ur sidelight wire and earth the black
smithy318i
Post Fri Mar 31, 2006 7:04 pm
bolt the U shaped one to the bodywork (bare metal)
and run the fused red wire to the sidelight wire.
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Fri Mar 31, 2006 7:10 pm
If it's the Depo lights the red (which should be the feed for the relay)should go to your +ve on the battery (or +ve terminal block on the bulkhead if it's a 325i) and black goes to -ve terminal on front suspension turret.
Taylor.
parksie
Post Fri Mar 31, 2006 7:17 pm
:D Cheers Dude's :D
Taylor --That's it, they'r Depo lights,it now makes sense having such long wires :clap:
