325i touring suspension specs
gareth
Post Fri Feb 25, 2005 5:36 pm
i've recently seen a lot of discussion about touring suspension and having m-tech stuff as standard.
recently i bought a full used set of 318is shocks with the intention of swapping over to stiffen things u a bit. the ones i bought are boge.
will these actually be an upgrade on the 325i touring ones?
i'm going to keep my current springs as it's at a nice (lower) ride height and looks good, i was just hoping for a stiffer set of shocks. if i swap, will it be worthwhile?
Hammer1
Post Fri Feb 25, 2005 5:47 pm
I wouldnt of thought a set of 318is shocks would be a upgrade on 325i m-tech dampers...Wouldnt they be under dampered?? due to the lighter 318is engine.
Might be best to check part numbers before you fit.
StuBeeDoo
Post Fri Feb 25, 2005 6:16 pm
As I understand it, Touring shocks are the same as MTech ones, but the springs are not MTech.
Now someone will come along and correct me!
HTH
Stuart.
gareth
Post Fri Feb 25, 2005 6:37 pm
spot the other semi-confused touring owner :roll: !!!
Andy335Touring
Post Fri Feb 25, 2005 8:18 pm
I just took off the original suspension on my 325 Touring and they were Boge dampers with the 51mm dia front struts.I think it was just the 325 tourings that had the M-Tech suspension as standard but i'm not 100% sure.
Rear springs have got to be from a touring or they will ride to low,i found this out the hard way.
I was going to use Spax M3 springs all round but the rear was to low for my taste,i ended up using Spax M3 front springs and Spax Touring (-40mm?) springs for the rear.I'm also using adjustable spax dampers.
Excuse the dirty car but this is the only picy i've got of it with the new suspension on.
gareth
Post Fri Feb 25, 2005 8:39 pm
that looks like a very similar ride height to mine. i assume the springs are correct but it's still on std shocks so tends to ride on / near it's bump stops.
boing boing! :?
i assume any set of adjustable shocks would llow me to use my current springs and set it up nicely. right?
andyp
True Old Skooler
Post Fri Feb 25, 2005 10:30 pm
i also found out the hard way, as the saloon springs are way too low
E30WEZ
Post Sat Feb 26, 2005 12:16 am
Mate if you want to meet up you can have a look at mine as it's running all standard so should be m-tech.
WEZ
gareth
Post Sat Feb 26, 2005 9:20 am
i may just do that... u going to any of the meets soon wez?
E30WEZ
Post Sat Feb 26, 2005 1:22 pm
I may have a bit of a problem with the Brighton one but i can pop and see you as your in town :D
WEZ
