Petrol Smell and burnt oil
bmwe30mtech
Post Fri Mar 31, 2006 4:06 pm
Hi,
When i start up my car and for about the first 10 minuites (if not longer) there is a smell of unburnt petrol in the car, and it is stronger outside the car. Any ideas what this could be, i dont see anypools of petrol on my drive, so i dont think it is the fuel tank.
Also my M40 has burned 1-2cm's of oil in only 1000 miles, could this be related? :( Oh and my car still wont idle, i took it to bmw who couldnt fix it, and emailed ant a few times but with no reply. :(
Many Thanks.
Paul
kam-325i
Post Fri Mar 31, 2006 4:13 pm
Are you getting any blue smoke out of the exhaust....?
bmwe30mtech
Post Fri Mar 31, 2006 4:15 pm
Hi,
No the exhaust is a bit smelly and the fumes are quite prominent, but they all look white to me. I have thought that e30's in gneral are a bit 'fumey' due to their age?
tylerma
Post Fri Mar 31, 2006 4:17 pm
check the fuel pipe that goes into the fuel rail
they usually perish and crack
thus dripping petrol when running
bmwe30mtech
Post Fri Mar 31, 2006 4:20 pm
Ok, will do Malcolm. Roughly where is this in the bay? Also im guessing its fairly easy to replace, but wont petrol go everywhere?
tylerma
Post Fri Mar 31, 2006 4:34 pm
the parts I replaced on mine were 16 & 17
take the top half of the inlet manifold off
and you will see all
you will get a little fuel spillage
but the fuel will only run if being pumped
part number 13 31 1 703 489
you will want 2
they are about £4.50 each
bmwe30mtech
Post Fri Mar 31, 2006 4:36 pm
Thanks Malcolm, i will go and take a look some time today. Fingers crossed this is the problem as thats not too steep.
Thanks.
Theo
Post Fri Mar 31, 2006 4:48 pm
You wont really see any drastic quantity of petrol from a leak - it evapourates too quickly, get a torch and have a good look/sniff around.
By the way - what do you wanna do with this parcel shelf - im back down in Kent now.
bmwe30mtech
Post Fri Mar 31, 2006 4:55 pm
Ok, Will do, thanks. If its still going, i will take it so long as it hasnt got obvious marks where the blind went.
Thanks Theo.
