M40 flywheel into M42?
eko
Old timer
Thu Mar 30, 2006 1:35 pm
Is this a straight forward swap?
Basically my clutch is starting to feel sorry for its self,not quite slipping yet but shouldnt think it will be long so i was thinking,will it be worth fitting the M40 flywheel while im doing the clutch?
Is it as simple as fitting the cluth/flywheel or will i have problems with the gearbox not fitting anymore?
Anyone got any experience of this swap/any advice?
I do have a 316i(M40) that im breaking so any parts i need i can scrounge from that?
(Apart from clutch which ill buy new)
Thanks in advance :)
Gwynleym10
Thu Mar 30, 2006 2:41 pm
yes should fit fine, Its lighter than m42 as well! (I assume you know this though...)
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
tim_s
Thu Mar 30, 2006 3:18 pm
there's varied info on this, i've got one i'll be trying when i do the engine swap so can let you know definitively.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
eko
Old timer
Thu Mar 30, 2006 8:02 pm
Im sure ive read that the 318is box has a different size input shaft so dont know if this will cause problems?
Anyone else add anything to this?
Would like to do it soon before i get rid of my breaker!
m-dtech
Unapproved Trader caution
Thu Mar 30, 2006 9:52 pm
well if your doing the clutch then all i can suggest id that you offer the parts up to each other to see if they fit.
eko
Old timer
Thu Mar 30, 2006 9:54 pm
I agree but im not taking the 316i apart if i dont need the bits and i dont want to buy a M40 clutch instead of M42 clutch if i dont need to,unless they are the same?
StreetSpec
Fri Mar 31, 2006 2:54 am
AFAIK you need the m40 flywheel, clutch and pressure plate. havent heard about the input shaft thing tho.
