Clock
Fiona
Post Thu Mar 30, 2006 12:56 pm
Hi
How do I set my clock in the centre consol?
I not sure if its broken or just not doing it right?
Also my speedo is being irrectic, sometimes working and sometimes not?
Is it feed from the gearbox or the diff?
Cheers Guys
tonyppe
Post Thu Mar 30, 2006 1:00 pm
from the battery or power first being connected its straight forward. just press the h/dat and min/dat to get right one.
otherwise i think you hold the h/dat in hour mode, or you hold the hour button to start it off. your right tho, it is a bit weird.
Geeman
Post Thu Mar 30, 2006 1:14 pm
Speedo reads from the diff. Easy to replace the sender unit.
Fiona
Post Thu Mar 30, 2006 1:15 pm
My clock/computer is like this!
tonyppe
Post Thu Mar 30, 2006 1:27 pm
thats cos you have a propper car. :mad:
i only have the 1.8 style clock.
Cloggy Saint
Post Thu Mar 30, 2006 1:34 pm
push the small recessed button in the bottom right hand corner with a pen or something. Then use the 1000, 100, 10 and 1 buttons to set the time. When correct push the small button again and the time is set. Same process for the date.
Fiona
Post Thu Mar 30, 2006 5:04 pm
datourer wrote:push the small recessed button in the bottom right hand corner with a pen or something. Then use the 1000, 100, 10 and 1 buttons to set the time. When correct push the small button again and the time is set. Same process for the date.
Cheers, will try later!
orangecurry
Post Thu Mar 30, 2006 10:10 pm
Fiona wrote:Image
The clock is wrong because someone has stolen your car - the clock needs the car for electricity winkeye
Fiona
Post Fri Mar 31, 2006 10:51 am
orangecurry wrote:
Fiona wrote:Image
Lol
I copied the pic from ebay! :D
