Right, so i'm close to getting my hands on a steering rack out of an E36 M3, and i was hoping to fit it to mine.
I have read however that it is very difficult to get this to fit on an IS because of the tubular manifold?
Also, I understand the steering UJ mod issue, but why do you have to get new pipes made up?
E36 rack into 318is
TheDutch
In this case very difficult means using a different exhaust manifold. Don't bother going any further with the other stuff unless you are prepared to do this or come up with another solution; the line the coupling wants to take is through one of the down pipes.
The hydraulic lines are different to cope with different pump/reservoir locations and, more significantly, different connection points on the steering rack.
Dan318-is
So would you say its next to impossible?
jmc330i
If you keep the original manifold, yes.318-is wrote:So would you say its next to impossible?
You could have a go at modding the original to fit around the steering joint - but from what Ive experienced doing my S50 manifolds, its no easy job
A custom manifold would be an option, that way you could have it built to fit, but that wont be cheap
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Jamesb318is
Arse! Oh well, thanks for the help anyway guys.
