firsty its a 325i dreg bmw the vechicel starts and pulls great no over heating probs etc but when the engine comes to idol around 1000rpm its runing lumpy (had a engine tuner out and said ( no1 and six were slighty down on comprestion , so ive had the head skimmed/tested and regrinded and re fiited the engine seems a bit better but still lumpy replaced all the inlet and head gaskets, but ive noticed theres a strong smell of feul from the rear of the car ,,can u help
ive included a couple of phone vids if they work (ignore the noise as phone speakers are crap ???
[img]View My Video
[/img]
bmw e30 engine issuie can u help ???
fuel smell could be either the filler neck connector corroded where it enters the tank so check this area. Also check down in front of the passenger side rear wheel area, this is where the fuel pipes come from the tank and are known to corrode there. On my facelift car there is an external fuel filter there too, not sure if it is on the pre-facelift cars like yours.
adaptorman
hi thanks for the quick reply i shud av said its from the rear exhust pipe (strong smell of feul )E30BeemerLad wrote:fuel smell could be either the filler neck connector corroded where it enters the tank so check this area. Also check down in front of the passenger side rear wheel area, this is where the fuel pipes come from the tank and are known to corrode there. On my facelift car there is an external fuel filter there too, not sure if it is on the pre-facelift cars like yours.
adaptorman
hi this wasnt the link i posted (it was of the engine? there white feuly smoke coming from the rear box any ideas please
jmc330i
?????adaptorman wrote:hi this wasnt the link i posted (it was of the engine?
Dont know what happened there - I just copied the link from your first post and thats what came up.
Sorry, I cant help with your problem, just thought Id put the link up to vid.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
so an overfueling problem or something similar by the sounds of it, prob best to wait to hear from someone like Brianmoore or Ant.
Could be the setting on the air flow meter but don't meddle with it without advice as they can really be a pig to set once you start losing track of how many turns you have done to the screw. But could also be electrics like dizzy cap, rotor or a crap plug not firing on a cylinder properly.
An air leak could possibly also cause this problem so check the rubber bellow for splits and check breather pipes and vacum hoses.
good luck fella, probably something daft though
