(_ 230 Miles to a 55L tank__)
as above gentlemen, this is in a 325i no mods. sound reasonable,. and its a consistant 230miles to from full to redlight after low petrol mark,. self explanition really? what is anyone else gettin 325i only please. this is on an E plate, 1st edition facelift. thanks guys.
mrLEE30
get similar in both my sport and 320cabby, less if the bA/C on in summer!!
also of course depends on where and how you drive. ie. 60mph all on motorway will get loads more miles than caning the arse off it round twisty roads, but i am sure no zoners do that!
mrlee
mrlee
20 quid gets me 150 mile ish.mines got bbtb and zone chip.
that .auto will use more.if its manual think you need to have a look.
binding brakes
tyre pressures
coolant temp sensor.blue ecu
basic service items,plugs,leads,cap,arm,valve clearances,
obviously fuel leaks.
what is your diff ratio.how many rpm top gear at 70 mph?
binding brakes
tyre pressures
Alpina C2.5 manual = 240-260 miles on 50L(22-23mpg). Depends on the type of driving and duration etc, but that's a longterm average on plenty of mixed driving.
325i Auto = 220-240 miles on roughly 50L, doing the same sort of driving.
Both cars can manage 26-28 mpg at reasonable motorway speeds, anything 90mph+ starts to eat into fuel economy!
i get just about a 100 miles for 20 quid on my 320i Cab, i use half local and half dual carriageway, is this normail?? Is there any other 320(dont tease) cabby's..
f**k me how are u driving!
my 325i auto does 360 miles to a tank
my alpina 2.7 managed 350 all m-way at 80 plus when i drove it home last week
my old sport used to 300-330 on average!
exactly the same as mine was getting and i aint got a cab.It does seem to have improved (slightly)) since i fitted a new thermostat the other weekN4SBM wrote:i get just about a 100 miles for 20 quid on my 320i Cab, i use half local and half dual carriageway, is this normail?? Is there any other 320(dont tease) cabby's..
89 325i touring
did 240 in my tech 1 from london to leeds not dropping under a 100mph 95% of way
all on £30 bargain
and its running rough as hell and missing too
all on £30 bargain
www.oldskoolfantasy.co.uk
Geeman
- Contact:
My Tech1 Sport would manage 320 miles from Grimsby to Bournemouth (when I was a student type)... and I never used to hang around. 80 - 90mph most of the way, with fast blasts in between.
230 isn't very good.
Morat
I was chuffed last week - I got 260 before the light came on in my Touring. Its been 220-230 up till now. Then again the fuel gauge doesn't work properly, so i'm just hoping the fuel light is accurate!
(always take a can!)
Morat
well yeah - but frankly we all are...oze30 wrote:so basically.. I'm getting shit consumption!
Just confort yourself with how much you are saving on depreciation!
I just got my 325i sport H reg (swapped for a N reg Micra Super S) the car needs some work, oil leaks fuel filler neck and fuel hose replacing.
When I got it it was using about £20 to do 130 miles
and that was all motorway. After noticing a smell of fuel when driving hard looked at it and the fuel return hose of the pressure regulator was pourous changed all the fuel hose in the engine bay and now I do the same journey on £12 and round town its a million times better.
It was mostly leaking when gear changing which is when the fuel regulator dumps lots of fuel down the return.
To check this start the engine then squeeze the fuel return pipe and if buggered it will weep around the unions to the regulator.
Hope this helps, my mate used to work as a BMW technition and he said the e30 6 cylinder engines murder there fuel lines all the time due to the extra heat in the engine bay.
If I can't fix it I'll f**k it up so bad nobody can!!
TouringMatt
Got 373miles out of 54L at the weekend, mainly Mway/DC but some stop-start stuff too
89 325i Touring
Matt
89 325i Touring
Matt
When you have 2 sp30's on you like me which gave me 11 points flower driving is the only way
Unless your in a built up area where they can't prove squat!!!
