HELP 325i auto not starting
Aziz
Post Mon Mar 13, 2006 11:50 am
Hi
My 325i was starting fine, but today
It will not turn over or start, when I turn the key all I hear is a single click coming from a switch marked S - E - 123.
I think it may be the inhiblator switch.
Also in P the car does not move, but select any other gear Drive, Rev, 123 and it moves, is the cluch dis-engaged?
How can I get the car started again?
Is it possible to start the car without the inhablator switch? HOW?
All comments and ideas gladly welcomed.
Imran :cry:
Quaser
Post Mon Mar 13, 2006 1:03 pm
HI Imran
I think that it is a starter motor issue, as i had a similar issue with my cab.
Try jump starting it - this would normally allow it to start with mine.
The issue turned out to be the yellow/black wire which goes to the starter - it was broken internally. I connected up another cable to inside the cabin under the glovebox. You can disconnect the faulty cable and connect up the new one there.
Q
