hi: guys
if your alloy wheel is damaged badly kerbed? could u still hav it repaired even if there is a chunk missing from the edge?
damaged alloy wheel question
kam-325i
Depend on how big the chunk is and the quality of the wheels....
Taz
its a big chunk on the edge but a tyre can b sealed on it
but how does it get repaired do they weld a piece on it? wat about the balancin etc how much do ya think it might cost?
cheers
cheers
panesar_e30
most companies will not touch them. is the chunk missing on the inside or outside?
if on the inside all you can do is paint them silver as you cant get them straightened either because of balancing issues.
p.s another thng i forgot to mention, they will keep on cracking no matter how many welds you have done. its happen to me before
Taz
the chunk is missing from the outer edge
panesar_e30
find out just to mke sure, its the same case when the wheels are cracked.
