I've started to fit opening rear windows but run in to a problem - Help!
I've managed to remove the old fixed windows but when fitting the new opening ones, I can't find the bolt hole for the catch in the rear window pillar. I've noticed that there are a couple of cuts in the foam under the roof lining running down the pillar but can't locate a bolt hole - can anyone give me any tips?
Thanks,
Cava.
Opening rear windows ...
FESI
check in the tech article section
Cava
Cheers mate, missed that one!
