ok, if any 1 has been following this thresd
http://www.e30zone.co.uk/modules.php?na ... highlight=
this is the latest development.
after changin relays ecu sensors,cut out imobiliser, i have found the fault. well ish.
there is a perminant red wire goin to the relay on the passenger side wheel arch but the air box.
I seema as though this wire is braking down. it always has power(tested with power prob) it's just how much. when the tester is in and there if full power the car starts, when there is a lower voltage it does not.
wat i need to know is where does this wire go? and can i just put a new perminant feed in place???[/url]
where does this perminant red wire go???
shelle-smokeahama
IIRC, it's other end, via a joint or two, is one of the small ring terminals bolted to the battery + connector. Probably a bad connection here.
shelle-smokeahama
yer i was gonna go 4 1 of those terminals. if that fails me next thing is to put in a new.
to be honest the way this car works will prob be something else.
