Need advice - my car has had no security fitted to it since new! Its definately a 'virgin' with respect to alarms etc. Since I don't trust that this luck will continue, what do I fit that will keep off the local scum and not mess the car up too much???
If anyone knows or can recommended someone in the NE of england I'd be very grateful!
Security - what do you recommend?
Templ8e30
The Toad AI606 is the dogs danglies. I've never had any bother with Toad alarms but lots of reliability issues with Clifford so I steer well clear of them now.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
cliffybabe
- Powered by Nelly
im in the same spot now looking for a alarm for my cab, it has some doggy little slot in imob that looks like a chewing gum paper work work in it, and it also has that 2nd key on the drivers door however i dont have that key, if i could get that sort of key from anothe rone would it work with programing??
kam-325i
- Contact:
Get a system that has a good, proven Cat2 immobiliser, as any alarm wont stop a brick through the window, it will only let you know that it has happened, you want to stop the gits, or at least hamper thier efforts, at driving it away.
